I installed BD2013 for the first time a week ago, based on the rave reviews. Since then, after being logged in for 1 to 2 hours, the incessant memory accessing begins - the culprit appears to be vsserv.exe. This continues for up to four hours. During that time my system c-r-a-w-l-s. Then it stops and I can work at normal speed. Then it starts again for an hour or two. And so it goes until I run out of memory and can't save my work (Photoshop message saying there's not enough memory to save a document). I have to trash my work and reboot. Then it all starts over again. This never happened with my prior security software while working on multiple documents many times larger than the ones I can't save now.
As an experiment I rebooted, launched Adobe Photoshop CS5 and nothing else, and left. When I came back a few hours later the CPU was grinding away as described above. It has also happened while the only program I had open was Firefox (15.0.1).
Before I uninstall and abandon BD, I thought I would find out if this is a known issue with a fix.
Windows XP, SP3
1.86 GHZ, 2 GB Ram
Dell Precision PWS390
BD Build: 16.22.0.1534
I'm not a techno-geek so any fix will need to be fairly simple to do. If this is not a known issue with a fix, please provide instructions for fully uninstalling BD so I can go back to my prior security software. Thank you.
