Christian, in your article "How To Create A Zone In Bitdefender Firewall" you advise on the settings for the network type. However I can't change any of the values. For the Stealth mode, I can see the options are Remote/On/Off yet the setting remains fixed at Remote whatever I select.
I'm running Windows 8/64 and trying to network with my wife's PC running Windows 7/64.
Pings work OK, and I can see the other PC in Windows Explorer. I use CodeTwo Outlook Sync to sync our Outlook calendars which works OK, but I can't share files and can't set up a Homegroup.
I've read page 109 which you refer to in another posting, but I can't change anything. Help please!
Nigel
