guten morgen, komischerweise geben meine PC Lautsprecher (Hama) keinen Ton mehr von sich nach der Installation von Bitdefender Antivirus Plus..an den Kabeln liegt es nicht,auch nicht an Treibern. Woran könnte das liegen?
Kindly contact Bitdefender support by visiting https://www.bitdefender.com/consumer/support/help/
Select, How to's & Troubleshooting Bitdefender products→Troubleshooting→I don't know→Contact Support→ You will get the option of chat, call or email.
To get immediate update, make use of the chat option.
Also, ensure you do not have any ad-blocker or privacy-blocker extensions enabled, as they might prevent the chat window from appearing.
hmm..ok. i wrote to Bitdefender Support.. waiting for Answer now.
I could try to uninstall the Bitdefender AV,and then try again..
