If you are running Bitdefender AV 2011, can you run Adaware anti spyware programme or similar along side it without problems?
Hi Rik,
We should have:
1 and only 1 firewall.
1 and only 1 antivirus.
1 antispyware.
You have the antivirus version? there are antispyware and antirootkit included.
Deinstall your Adware antispyware.
L.
Thanks for the info Lionet. I only have Bit defender AV 2011 installed any way.
As long as the second security solution you would like to use does NOT have a module for Real Time Protection, you should be able to use it along with BitDefender without any issues. If you encounter issues with it please let me know.
I would like to remind you that I only recommend using a secondary security solution along with BitDefender Antivirus but not with BitDefender Total Security.
Regards,
