Bit Defender keeps on showing below warnings?
How do I fix it permanently?
Thanks,
Naveen
Hello @navzen2000,
Based on your description of the situation encountered, I would recommend contacting the Technical Support Teams, as more information might be required to troubleshoot this. You can get in touch with our engineers by choosing one of the contact methods available here:
https://www.bitdefender.com/consumer/support/
Scroll down to the bottom of the page and choose your desired contact channel.
