I have noticed my battery is draining quickly on my M1 Max Macbook Pro. On investigating, I am seeing BDLDeamon at 196% for long periods.
Is this a bug? How can I reduce the cpu usage?
Hello @@Pixor,
Can you perform a system scan, see if the results show anything unusual, then check if the high cpu usage persists? You can also consult the article below for things to check first:
In the event the issue is still there afterwards, I also think it may require a more in-depth investigation and would recommend to contact our Support engineers, for further assistance and advice.
