I did post this on reddit also, but here it goes
Has anyone else had your web browser(s) stop loading webpages, then after a bit your BitDefender is slow to open from the system tray and when it finally does it acts as if you're not logged into your central account and prompts you to login?
Restarting the computer fixes the problem. Full System scans turn up no issues.
This is a recent issue, within the last 2-3 weeks. The issues may themselves be unrelated and just a coincidence, or maybe the internet connectivity issues are causing BitDefender to think I need to login?
I have also scanned using on-demand (No active protections from them) scanners from ESET and MalwareBytes and neither of them found anything either.
