where can i find a replacement power cable? is there any alternatives?
Kindly contact Bitdefender support by visiting https://www.bitdefender.com/consumer/support/help/
Select, How to's & Troubleshooting Bitdefender products→Troubleshooting→I don't know→Contact Support→ You will get the option of chat, call or email.
To get immediate update, make use of the chat option. Bitdefender support may require logs and will assist you in generating them.
Also, ensure you do not have any ad-blocker or privacy-blocker extensions enabled, as they might prevent the chat window from appearing.
Hi,
I don't think they still have those in stock, but as an alternative, a router cable should do the trick. Based on my findings, you can use 100-240V AC to 12V DC 3A Mmgoqqt, standard EU.
Regards,
Alex
